03 Marauder Original Specs?
Lencac1
Hello Guys/Gals: Lencac here. Question I have I'm sure the majority in here can answer. What is the original, late 02 manufacture, stall RPM supposed to be? Where can I find info. on what the original factory camshaft specs. are?
You know you guys saved my hide almost a year ago by reminding me about the rear axle thing. Both my axles were failed. But nothing Ford Racing 4:10 gears, new axles, bearings and seals, Ford Racing diff cover and $1500 can't fix ;)
Anyway, thanks alot
Lencac
Did you get a tune for the 4.10 gears? Speedo and shifting will be off if still using OEM tuning. the exhaust cams are same as 98 Cobra, intake cams are a little different. Factory stall I believe is around 2200.
Yep, it's got a Mo tune for the 4:10 and 93 oct. I was hoping to get the actual specs on the cams so I can compare to any cams I may want to install in the future.
