06 CV SC part 2
I did this car several years back clean 2006 CV LX with a stock motor with Hi tech non blower cams that I hated, I installed LTH drive shaft 4:10 the owner did remote exhaust dumps and the Kooks long story short he went all out, starting with a custom Pro line racing long block trick flow heads mild comp cams Manly rods and pistons ballanced and BP, add a Novi 220 8 rib setup 60 lb inj blo through Maf Aermotive FP, KB BAP and I started it today and it idles perfect more pictures to follow.
Here is the car on the dyno I should have base numbers tomorrow, one pipe needs powdercoated and I am going to have the alternator done as well, the car should make very good numbers.
Here is Pats new 14" kit I willhave the front calipers tomorrow.
