There is a drone at certain low throttle points. I don't drive long distances with family in the car ( the wife would prolly complain).
Rick-n-Miami dynomatted parts of his MM (possibly the trunk). That should help. If you can get the ceramic coating...might as well...it looks killer under the hood, as well as cooling abilities.
also, if you can check all areas where the heat may affect other parts the headers come near, consider protecting those areas with heat shielding...I picked up a starter heat shield just in case i want to wrap the starter ....
good luck...the Kooks exhaust works ... I think it was def worth it.
