We just got out order of SCT live wires in today and will start shipping right away.
Pricing:
SCT Livewire $569
If you want a JLT and a Livewire I can make you a killer deal, just call.:coolman:
Gains below are from the tuner alone, not JLT and tuner.
Here's some info on the Livewire:
The latest offerings from SCT is the new Livewire tuning Device. The LIVEWIRE arrives PRE-LOADED with Dyno Proven tune files specifically calibrated for your vehicle. Simply select one of the pre-configured options such as 87 - 93 Octane Performance or Maximum Fuel Economy, flash your vehicle and enjoy driving until you are ready to have it custom tuned! Once you choose to have your LIVEWIRE device custom tuned, you can simply come back to use and purchase custom tune files straight from our website.LIVEWIRE can store up to 3 Custom Tune Files along with the factory uploaded tune while retaining the PRE-LOADED SCT tune files for future use.
The LIVEWIRE also features high speed USB data logging of multiple OBD-II PCM parameters, a dedicated wideband air/fuel monitoring port, the ability to datalog an additional analog signal, and real-time instrumentation. You can easily configure the LIVEWIRE display screen to show important information at a glance (*Air / Fuel Ratio, *Boost, Spark Advance). *Displays a converted 0-5v signal. In order to read your A/F OR Boost you will requires an external Air / Fuel Ratio device such as the LM-1, Wideband Commander or MAP Sensor for boost.
Measuring your vehicle’s HP, TQ, 0-60 ET, ¼ Mile ET and Fuel Mileage has never been easier. LIVEWIRE accurately estimates* your vehicle’s performance based on data monitored from the vehicle’s computer. Now you can easily measure performance gains before and after you make vehicle modifications, plus monitor your fuel economy. *Due to variables such as wheel spin all ratings are estimates only.
LIVEWIRE has a built-in, High Intensity Yellow LED Shift Light. Now, you can adjust your desired Shift RPM in seconds. LIVEWIRE is very accurate, it reads the RPM signal directly from your vehicle’s computer.
Using the LIVEWIRE Flash Device, you can now Read, Clear & Diagnose Trouble Codes without the expensive diagnostic fees charged by dealerships or your local garage!
Thank you
Jay
Pricing:
SCT Livewire $569
Thank you
Jay
