Todd TCE said:I have two sets of HPS pads on the shelf I noticed today. Not the normal pad today as not Wilwood. But I'll cut you a deal on them if you like.
Rear kits are few and far between but still doable.
Fourth Horseman said:Re: pads and transfer to the rotors: I've had very good results with the Wilwood BP10 pads that Todd moved me to. I have not had any of the pad transfer issues that I had with the Hawk HPS pads. Also much more quiet than the Hawk pads and they seem to generate more braking force, as well. I've noticed that under full braking from 60 or 70 MPH the ABS really struggles to keep up.
BP10 pads highly recommended. :up:
Question: does Wilwood make a pad for our stock rear calipers in BP10 compound?
Todd TCE said:The timing was good!
I'm not sure anyone can say anything bad about Hawk HPS pads however. I've never seen them have pad transfer problems. I'm curious to know if the problematic pads were not really Q pads and not HPS?
I'd say the BP10 compound and HPS are very similar in values. Both are modest street performance pads but NOT track pads. For you guys with some track plans I'd suggest a move into the BP20. Even some run this on the street with good results. But with the added wear and noise.
Todd TCE said:If you still have the old pads, the Hawks don't have any markings on the back but in one corner where they are makred SRS or something like that.
The Wilwood pads will always have a part number laser etched into them.
15Q-xxxx for example. The Q is the compound of the pad, the xxxx the part no.
