Todd, quick question if I may:
The non-caliper sides of these hoses, what type of flare do they take? Is it inverted flare, or metric bubble flare?
Thanks.
I received my kit recently. The only thing I can nit pick at are the brackets for rear hoses. They don't have tabs like the front ones that go into the frame to hold them in place so it's a bit difficult to tighten the bolt and hold the bracket so it doesn't spin with the bolt as you are tightening it.
Also as someone mentioned above the tabs for the front brackets are indeed a tad too big but that's easy enough to take care of with a grinder.
Been seemingly forever but I'm going to say there was no locating tab on the rear part I had here. Or it would be on it now. Interesting. Show me a pic. The front I can narrow on future runs.
Thanks. Can't say to what I had here years ago or not. From what you show I probably did. The issue would be the bend to a single plane of material that is thinner than what is shown there. I'll take a look, maybe get one and see if I can alter it for the next batch..some day!
