Is the whole not reading fuel pressure issue fixed now? What are all the parameters it will read on my MM out of the box and how long is the Cat5 cable?
Thanks Jack, I shall be buying one very soon then. 3ft should be enough, I was thinking about putting it in place of the stock compass but then I would have to look up to see it so I'll probably put it where Zack put his.
3 feet? No, that can't be right. Stock cable is 6 feet, and try as I might I couldn't get it to reach above the mirror, although I swear a couple of guys were able to make it fit. Luckily Joey included a second cable and connector and I ended up with about 3.5' extra that I tucked on on the tranny hump.
