2003-2004 Marauder bulb sizes
The sun visor bulbs are marked as 14V0.1A-CML. 4 total.
I took some measurements since that seems to be more of a rating than model number (?). 29mm long festoon. the caps being 9mm long each.
Looks like the 3022 is a compatible size..I think.
Check your lens, Looks like one of mine has a burn mark or something but no burn outs and all the bulbs are working, not sure what caused it.
attachment.php
The burn is common for incandescent bulbs.
Rule of thumb....
Incandescent = 15% of energy use is light, 85% is heat
LED = 85% of energy used is light 15% is heat.
BTW. I have some sweet LEDs for the mirrors.
Everyone keeps giving me the wrong equivalent model number for the 14V0.1A-CML . I got 4 Sylvania ZEVO Led DE3175 which is also 12818 3021 3022 3175 6428 6430 equivalent. Was told they would fit since it is 3022. Nope. All light people seem to reference that same wrong light list (the ashtray light one). The metal end caps are too fat to fit in the snaps and it hits the lens from being too fat.
attachment.php
This bulb is called 6641f, among other things.
It would be interesting to see what the Ford P/N is on your EATC's.
To my knowledge if your EATC bulbs are like this:
And the solenoids are like this:
Then you have an older EATC or an F150 EATC (yes they are the same and it's a BI**H to replace the o-rings but it can be done).
If the bulbs are soldered in and the solenoids look like this:
Then you have a newer unit.
In any case, I can repair them all.
Hey do you have pics of leds installed ib the eac and how much do you charge
Sent from my SM-G970U using Tapatalk
It's not just the bulbs. You need to install other "parts".
I charge $45.00 to replace the bulbs for the button & fan wheel lights with LEDs and replace the o-rings.
Bulb Replacement Guide
https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/
Vehicle or Part
2003 Mercury MarauderChange
Bulb Position
Forward
  • Fog Light Bulb Front
  • Headlight High Beam and Low Beam
Exterior
  • License Plate Light
  • Turn Signal (Rear)
  • Turn Signal (Front)
  • Tail Light
  • Side Marker Light Bulb Front
  • Side Marker Light Bulb Rear
  • Parking Light
  • Center High Mount Stop Light Bulb
  • Back up Light
  • Brake Light
Interior
  • Map Light
  • Turn Signal Indicator Light
  • Trunk or Cargo Area Light
  • Courtesy Light
  • Engine Compartment Light
  • Dome Light
  • Glove Box Light
  • Check Engine Light Bulb
  • Automatic Transmission Indicator Light
  • Ash Tray Light
  • Instrument Panel Light
  • High Beam Indicator Light Bulb
Vehicle Note
Compatible SYLVANIA Products
Actual bulb numbers:
Headlight – 9007 (2)
Fog Light - H1 (2)
Rear Stop Light / Turn Signal – 3157 (4)
High Mounted Stop Light – 912 (2)
Front Map Light – 168 (194) (2)
Rear Light (long overhead console) - 42mm Festoon (1)
Glove Compartment – 168 (194) (1)
License Plate – 168 (194)
Trunk Light – 2122 Festoon
Underhood Light – 906 (2)
Parking Light - 3157NA (amber) (2)
Vanity Mirror – 29, 30 or 31mm 6641 (4)
Rear Reading Light – 45mm Festoon (2)
Front Foot Well – 168 (194) (2)
Reverse - 3156 (2)
