SEP 2014 Updates
Time for some updates on this "epic" (timing) project.
TRANSMISSION - we said screw it with all of the big rebuilders - they all want an arm, leg and left nut for a rebuilt transmission, and that doesn't even include shipping to where we are. Seriously, I bought my complete Cobra pull for less than they're asking.
So instead, we bought a master rebuild kit from PATC (#12 on this crazy webpage:
http://www.transmissioncenter.net/aode.htm)
Interceptor master rebuild kit. This the same exact parts list we use in our Interceptor transmission. This package deal comes with: a quality master rebuild kit with Alto clutches, the new mechanical diode kit that came on the market in 1999, eight count Alto Red Eagle direct clutch Power Pack, high performance Fairbanks TransAction Kit, oversize overdrive servo, carbon fiber overdrive band, heavy duty converter with oversize clutch (#13) with 1800 stall speed, filter, spiral snap ring, pressure spring and valve or pressure spring and the freight is free anywhere in the 48 United States.
...without their 1800 stall converter, and then added a hardened intermediate shaft to the order. We will have a local guy rebuild our working low miles transmission for under 2K and save about 3K getting one built by the other guys. The JMOD steps are covered in the Fairbanks TransAction Kit, which comes with improved springs as well.
We also got this tailshaft forced lube cooling mod from Blue Oval:
http://www.blueovalchips.com/index.php?l=product_detail&p=74
With winter approaching again, we've been working on it less and less and only on weekends. Courtesy of Alberta, here's what we had a week ago (Sep 8):
Lots of wiring being done now, the same amount as I showed in my stereo install thread and most of the same steps. We have also been mounting gauges and running wires:
I never cared for the ricer pod before, but now that I have it all set up in Dad's car, it's starting to grow on me. One problem is it takes away from the sleeper aspect of the car.
Finishing up all the measuring, fitting, and mounting of the coolers:
(engine oil and trans fluid coolers made be DERALE)
Hot marauders go slow. Dad doesn't want a slow marauder. This is a $1400 FLUIDYNE radiator and DERALE set of fans and shroud.
I am looking forward to datalogging his car vs. mine (with stock rad and smaller fan) and comparing the engine temp differences. The car really likes to retard the spark at elevated temperatures.
The cooler at the bottom is for steering fluid. This car is getting the best of everything.
