245/50/18
airjordan2k8
Quick question does anyone have a pic with 245/50/R18 tires all the way around?? cause this is what im looking into getting but i really wanted to see how this size looks...
If you have a 300A, the tires will work well, just adjust the the rear airbag sensor to keep same tire clearance.
If you have traction control, you will have problems.
300A here... and would you happen to know how to do adjust that or i guess kind of explain on how to do that?? i dont really know how to work on cars either so that would probably help me out... thanks by the way
There is a procedure in the Service Manual. Do a search and you should be able to find the procedure. I don't have it readily available.
Those tires are probbably the ones with "Mount this side in" stamped on the wrong side. Make sure you mount them opposite to that.
I'm betting they won't work on the front.
how would i know if those are it? so you think i should just go with the 245/50/18 all around?
The squiggly tread pattern is supposed to be on the same side as the "Mount this side in". They stamped them wrong. If you are getting these for $115, that's what they are. I have them on my car. Don't worry about it.
The standard rear is 245/55/18. I'm assuming this is the tire we are talking about.
I had 245/50R18's on all 4 corners on my 03, at that point I cared more about tire rotation than the stagger look. It looked fine and fit fine. I did have one cut coil on the factory springs up front.
