You guys got to learn the web surfing tricks...
I shortened the link Smokie posted.
Go to http://www.mn12performance.com/mn12-techinfo/trans-tech/
Found the files. Right click and save to your harddrive. Then rename the file with only ".wmv" at the end of it.
You can also open the .htm or .html files in Internet Explorer and do save as into a directory, and it should save the web page and all .jpg/.gif in a directory to go along with the web page.
Get 'em while you can!![]()
Just curious, has anyone driven a MM with the two different trans and felt the difference?? (4R7OW vs. 4R75w)
There is no difference in feel between the 2.
The only change beside the slightly tighter torque converter is a minute change of the internal gear ratios and the number of holes in the Output Shaft Sensor.
