Turbo4v06
Brake cleaner.
Tried that, sprayed everything but the black line
Brake cleaner.
Brake cleaner.
That car needs to be submerged in brake cleaner haha.
You forgot to mention that weird sound that sounded like a vacuum cleaner sucked a piece of paper, came from passenger side
Lol you gotta catch it first.
Bro don't give that loser a platform to stand on
Na, low n slow is the way I go. Haha
That's that Florida heat... Glad you found the suspect... Chive on :beer:
I need Help. this item has a small leak the vacuum reservoir (black box)? it is on driver side, inside, above the left tire. Where can I get a new one I looked at Rock auto, no luck. The tire on that side wore a hole in it we fixed the hole still has leak in the maximum position. About 2;RPM we have improved it a lot. Decided to replace the box.
Any help would be great. Hoses are goo etc sb
Not sure what you mean by "keep up with". All the MAX setting does is turn the temp down to 60°, close the Recirc/Fresh door, and turn up the fan speed.it causes the Vacuum air, to not keep up with the Max air button.
