I have just installed the Suncore compressor and air bags on my early '03. I cannot get the bags to fill.
The comp comes on for maybe 5 seconds and stops. After the comp runs and I haven't done anything to release pressure from the lines, it vents a burst of air before running again.
It seems the Solenoids are not energizing. When I disconnect the air line from a solenoid I get a blast if air. When I run the pump with the line disconnected air blows out. I've run the comp with the solenoid hooked up but removed from the bag and nothing comes out.
I've checked fuse 16 and relay 304. I tried to check voltage at the plug, but it appears the solenoid needs to be connected for the system to do anything. That kind of leads me to believe it's not a wiring issue since if there were an open, the system wouldn't work at all.
Initial cause for replacement of comp/bags was a rotted out pump. Any suggestions on what to try next?
