Alignment guys (Fox body Mustang)?
With 0 toe you are going to have a car that drifts, you need some toe if you want to keep it going straight whether it is "in" for general purposes or "out" to improve turn in response you really want some toe.
negative caster will cause drifting or instability. toe does not effect pulling/drifts
Yes a lack of or no caster will cause a vehicle to wander but so will zero toe. Besides being a Ford guy I've got a bunch of IH's that the factory setting is zero or negative camber, but with a little toe they drive straight and true down the road no matter which side of the crown I'm driving on. Granted I'm in the Seattle area where they don't put a lot of crown on the road. However if you set up a car to not drift right due to a steeply crowned 2 lane road then driving in the left lane of a steeply crowned divided hwy you have a car that drifts to the left heavily.
^^^ "IH's" ??
So are you both suggesting that I should get a little bit of positive toe (toe-in) or just leave at zero? I'm thinking maybe that "camber-thrust" is going to cause a toe-out just slightly when the car is in motion. Zero on the rack may not be zero due to stock rubber A-arm bushings.
I should be trying to get the camber close to 0 then? (Ford sets at 0?)
The alignment guy said the adjustment plates on the strut towers, are maxed-out. I can't get any less-negative than the -0.9/left & -0.7/right.
Short of buying and installing camber/caster plates (which I have no intension); maybe I could just create more negative on the right then (maybe to match the -0.9)?
^^^ "IH's" ??
So are you both suggesting that I should get a little bit of positive toe (toe-in) or just leave at zero? I'm thinking maybe that "camber-thrust" is going to cause a toe-out just slightly when the car is in motion. Zero on the rack may not be zero due to some 21 year old parts.
IH's International Harvesters. Scouts and a Travelette (0 camber) Travelall (neg camber)
Yes I'd try a touch of toe in to see if that helps since the rest isn't adjustable anymore as is.
You may want to check out this article, particularly the toe-in toe-out section. http://www.mustangmonthly.com/techa...portance_of_front_end_alignments/viewall.html
