Granddaddy Marq
And the fix to the Problem Waaaaas?!
Try pulling a fuse for the accesories like the windows, AC, lights, etc and see if the alternator holds constant volts. That will help you narrow down where the problem is. When the alternator is under a load, the regulator will increase the output. Something in your system is putting a servere load on the system and putting the alternator into full field.
^^^what Jim said^^^Need a "Marauder-specific" alternator. Mustang ones will fit but they don't work correctly... as you just found out.
Oops.
AAP still has monkeys, though...
