Just to be clear here, what I'm after is not 1/4 times or peak HP, the interest is in more low-mid for better throttle response and seat of the pants gain when the mood strikes. I rarely get to the track, and when I do its only 1/8th mile.
In the past, I had a 3.8 V6 SC Thunderchicken that I did some pretty extensive work to, aftermarket upgraded eaton M90 @12+ psi, alky inj, cam, head work to include bigger valves and port work, and a AOD with wide ratio gearset, very mild non-locking converter, and stock 3.27 gears. This car had more down low and mid than my Marauder does and it was a V6; of course the Marauder makes alot more up top.
I bought my Marauder with the centri, not realizing how drastic the difference is between a centri and roots blowers; knew there would be a difference, but not so much. My prefrence if money were no object would be a twin-screw blower. That is not in the cards at this time, plus I'm not sure I would want to try a whipple or kenne bell on my bottom end (an MMR 600). I'm not interested in an eaton, I've had them and too much heat for daily driving. Next big project on down the road will be big block or whipple, might even be in a different car?
So without the PD option in the near term, I am trying to figure out how to get some more torque and better mid-range throttle response so I don't have to rev all the way up to get pushed back it the seat.
I would probably give up 20 or so peak HP for significant increase in area under the torque curve before 4500K RPM or so.
As for spinning the blower faster, I was thinking if could shape the power curve to hit harder eariler and peak closer to 5800ish RPM, I could pulley the blower as fast specs allow for a 5800Kish shift and call it a day, don't really care about the PSI. I imagine the PSI will drop a few lbs if the cams allow some more air in anyways.
So what I am after is info on whether these 98 cams in whatever combination would support such a goal.
Actually, this post by NA SVT on an other form shows the change in shape I am after, I'm curious how this would apply to a cenri car?
http://www.svtperformance.com/forum...3-04-heads&p=12636362&viewfull=1#post12636362
Thanks guys!
