MyBlackBeasts
T242 - Ricer ricer
Try this one:
Nope. Sorry, try again.Spanner wrench for a boat's fuel cap.
It's the heavy dutiest 55 gl. Drum cap removal tool I've ever seen.
You mean you don't let the fuel pump drive rod fall down, fumble about, cuss a bit, smear it with grease and then stuff it back in there?
Looks like a tool for a brake caliper piston. You know, those annoying ones that have to be turned back in.
That is a Moon shine jug corncob cork remover.
Use when Billy Joe Bob gets a little to drunk and knocks the corncob too far down in the jug and he can't get his 2 remaining teeth on it to pull it out.
Very rare tool, but still widely use in 4 rural Alabama counties.
Valve spring compressor for removing valve springs while head is on the vehicle.
Do you have the fittings for the air compressor hose also?
That's an idgit spinner.Ok, try this one:
BINGO! You got it Roger. Wow, that was fast!
In more detail: Early 1980s, GMs very 1st computerized ignition/fuel management system called CCC (Computer Command Control). Used this "key" to short 2 terminals on the under dash connector (think OBD2 connector but smaller). Shorting the terms would activate onboard diagnostics and give a blink code on the CEL.
My generation used a paper clip![]()
