A bearing kit with seals, shims, gaskets etc from Ford is only $112. Of course there is labor. Money well spent. Do it right and you won't smell 90W oil for another 100K miles.
I certainly hope so, but that isn't my point. It just sounds like you're saying that everyone will NEED to rebuilt their rear axle just because it has 100k miles on it.Many of us have higher standards than the cab companies.
I am saying clutches and axles will be needed about every 100K, at which point you are $100 worth of carrier and pinion bearings from a full rebuild.
All of the bearings do not need to be replaced.
We could argue this point, but considering how rarely this needs to be done (and the price of bearings) it is false economy to not replace all the wear items at the time the axle is disassembled for service.
And, as mentioned, given that a catastrophically failed axle and bearing is often the impetus, a thorough cleaning to get out the shrapnel is essential. Again, requiring disassembly.
I noticed a blown axle seal on the passenger side of my 2003 300A (build date 10-4-02) the other day and haven't driven it since. Prior to this, I had been hearing a noise that varied in frequency as the speed of the vehicle changed.
I used the search function and was able to find the TSB number 03-05-05, but that apparently only applies to vehicles under 36,000 and something about a Ford recall 04S16, which states bad bearings and improper lubrication could lead to axle failure in Crown Vics and Town Cars. Dealers were instructed to install p/n 3W1Z-4A109-AA Rear Axle Bearing Service kit, which consists of new axles, bearings, seals and 75w-140 gear oil.
I was just quoted $1100 + tax to have this taken care of at a stealership, seems pretty steep to me. Has anybody ever had this work done without paying that much (meaning for free or just a deductible) out of pocket?
Can you describe this noise? I get this very slight high pitched whirr from my rear end at certain rpms. Not sure if I should be worried or not.
