Lame lame lame advice ...
... pardon me if I step on some toes or insult a few here, BUT ... cams are about the last engine mod you need or want to do. OK, you might think you
want to do.
A typical hi-skool racer-boy thinks he wants a rough idle bad-boy sound to impress. A sophisticated, ultra conservative 63 year old understands practicality and real world performance. I could go on about life experience from "modding" my dad's '59 Ford when I was 16 years old, to present day, but please allow me just one example:
Around 1968, one of my best friends had a '65 Pontiac LeMans convertible with a 4 speed and a 326 V8. A really nice car. His girlfriend had her daddy's 4 door full size "big boat" Oldsmobile (automatic trans with a 394 V8). He decided to show her his macho-man driving skills and the Pontiac's power by blowing by her in a rolling start drag race. The outcome? She walked right away from him, leaving the Pontiac in the dust.
The OEM 4.6 4 valve heads have great flow, and are an excellent match to the OEM cams. First things first apply in any mods (staged performance), to any vehicle. In the case of a Marauder, they are:
1) A custom tune, such as from Lideo, or other vendors here. They gain hp and driveability, with improved shift points, and without any mods that can hurt the engine or trans. They also come with a program to use when changing to 4.11 rear gears, with matching shift points, and speedometer correction
2) A change to 4.11 rear gears, with an Eaton Detroit Trutrac differential, and (Ford) 31 spline axle shafts
3) The first 2 mods will get you into the low 14 second range in the 1/4 mile. Not quick enough? Try a cold air intake. More top end for Bonneville? Perhaps 3.08 rear gears and a tune to match
4) Headers and a tune
5) A 2 1/2" exhaust system, with Magnaflow mufflers
5) An Eaton supercharger, or else a higher stall torque converter
NOW you might want to consider cams, but you still don't really need them. I believe, a few years ago, the worlds quickest Marauder had an Eaton S/C with stock cams, cast iron manifolds and an OEM exhaust system on it.
