Shaft333
The Awesome
I did a search but didn't find anything specific.
Anyone else have an issue with their cruise control failing? Is there a common point of failure?
Mine is not working. I don't use it often so I don't know how long it hasn't been working.
If I recall there is no indicator lamp on the dash or otherwise to show that it is on. Is this right? (I remember thinking that was a real weak design) The service manual's test procedure involves a dash light.
This pisses me off. I also had to replace the compressor for the air suspension a month ago. I couldn't find a loose connection that may have occurred during that procedure, but I can look again if there is a strong case to do so.
