Well, time to revive this thread.
I finally have my Teksid block in at a local machine shop. Next week it gets the hot tank, torque plated and clean-up. We may be able to keep the 3.552 bore, just a quick square up and polish. 0.010 over are expensive pistons. I will be keeping with the stock stroke. There are lots of rotating assemblies put there, but I can see I will not be doing this on any sort of reasonable budget.
After tearing down the blown up engine, I have realized there is absolutely nothing I can re-use. The failure has put too much stress on every single component of the short block. I am not even confident in the heads at this point. Combustion chamber #1 is banged up pretty good. All the valves look good, but my confidence in their ability to go on is not there.
#1 connecting rod broke. #1 piston was broken into two major pieces and a thousand smaller pieces. The wrist pin shattered and wound up in the mix. All the rings were twisted and wound up everywhere in the engine.. #2 connecting rod broke. the piston stayed in one piece and in it's bore. #'s 3, 5, 6 and 7 had bent rods. Only rods that were looking straight were 4 and 8. The bloc has several ventilation holes in it. three on the sides from rods, two in the valley from the meat grinder of a crankshaft. Needless to say, it is n absolute mess.
Really not looking forward to spending $10,000 on a rebuild here. Heads are an unwanted surprise. I have no ide if anyone can repair a banged up casting at position #1. I will try to post up pictures of this mess. It's a lot worse than I thought.
I am now into Oil pump, pickup, windage tray, and pan, all are bent and damaged. The entire timing system has experienced too much stress.
