I hope this is the right place for this. Sorry if this was already covered somewhere.
I replaced EATC o-rings, and now I have new symptoms.
BEFORE o-ring replacement, I had no fan speed control and no vent selection control (hi-speed defrost only). But I was able to control the temperature.
AFTER o-ring replacement, I fully regained vent selection control. But TWO things happened.
1. The fan speed is touchy. I have some control (a lot more than before o-rings), but it still seems a bit erratic.
2. I immediately lost control of temperature control. After plugging the unit back in and testing the vent selection, I tried to change the temp and I immediately heard the blend door motor clicking, then it stopped and all temp control was lost. I reset the code and it happened again. Freon and compressor are good.
So the obvious question: what's going on here? The timing of the o-ring replacement and the new symptoms seems suspect. Why would fixing the vacuum issue within the EATC cause new problems in the blend door motor and potentially the blower motor?
