Emission inspection NJ S/C Marauder
HD4
Do Right and Fear No Man!
Any super charged Marauder owners have trouble with passing emissions inspection with car in NJ?
Thanks,
Mike
Does N.J. inspection actually check the tail pipe or just see if there are any codes?
Either way, your probably OK, even if they check under the hood as most techs won't notice anything out of place......
NJ checks at the tailpipe.
NJ checks OBDII (computer). You can get the tail pipe test from a private inspection place at a cost of about $50 bucks. Good for 2 years. Ms. D's Zack tuned car wouldn't pass the OBDII (stock) but sailed through the tail pipe test no problem without returning the car to a stock tune (which she no longer even has)
Take it from me, they use OBDII...... My Trilogy failed because of failed/unavailable sensors.
When the weather improves, I'm getting her retuned.
I called a garage and they told me they wouldn't touch it. I'll call others.
So most are saying it will not be an issue as long as no check engine light on?
Not so?
Unless it changed in the last year when I took the truck through they checked the tailpipe I know becasue I watched! It was done at the Bakers Basin Road station in Lawrenceville on route 1.
If it turns into a problem, I have $8.00 put aside :D
Heavy duty trucks over 8600 or diesels.
I have a spot that works on tunes I am taking mine in soon so they can retune mine. There Address is 3100 Route 73 North
Maple Shade ‎ NJ‎ 08052 undercoverperformance.com
United States
Sent from my iPhone using Tapatalk Panther
United States
I just heard about this place.
I have to check them out.
Unless it changed in the last year when I took the truck through they checked the tailpipe I know because I watched! It was done at the Bakers Basin Road station in Lawrenceville on route 1.
Guy in Washington told me they wouldn't do a TP test on a car as new as a MM. I think those guys make up the rules as they go anyways. Powertrippers.:shake:
Finally passed at a private garage with the Zack tune intact. Guy said it was one of the cleanest TP tests he'd seen. Stupid State of NJ
I just had my 06' STS-V inspected at NJ inspection station no problems. but its stock super charged.
Stock '95 F-150, stock 302 V-8 at the time of inspection about 79K in the clock.
BDJ, I think the OBD test is for '96 and newer anyway. My '72 Olds had to pass emissions(!) last year, which was a little tricky.
My non-SC MM just passed NJ inspection in January. I had to remove my Lidio tune and put over 100 miles on the car without the tune to allow for sensors to reset/become "supported". Passed the OBD test; no "check engine" light, no problem. I'm getting good at this :rolleyes:
