kmastl
I will most likely be buying my first marauder on saturday. I plan on doing an upgrade of the factory stereo. I am open to suggestions but I am set on keeping the factory head unit. I will be running an elemental deisgns NINE.5. An equalizer will be used.
My question is do the front speaker outputs on the factory stereo have a flat responce? I will be using a line level converter made by PAC to go to the EQ.
One more question. I am going to use the factory wiring for the front two channels. What I am looking for is a wire harness that has the factory female on one side and a factory male end on the other so I do not have to splice wires behind the factory connection. Where can I get something like this?
Thanks, Ken
Thanks, Ken
