Head Lights
Murader03
Contributing Member
Guys:
Found a little know/documented thing about the headlights. I stopped for gas the other morning and didn't want the lights on while I was pumping. Left the car run as it was about 20 deg. and wind chill about 5.
So, I turned the lights off from the far left, automatic position. The lights failed to turn off. I found the lights would stay on until I turned the ignition off. Once the ignition was cycled, the light operation was normal. So, if your stopped at night, with auto lamps on, and turn them off manually, don't be suprised if they stay on till you turn the ignition off.
If you had turned it one notch further to the manual parking light setting, and THEN turned it back to off, they'd have gone off.
Now having said that, does anybody know a way to adjust the sensitivity of the headlight sensor so the headlights don't come everytime a cloud passes over?!
**If you had turned it one notch further to the manual parking light setting, and THEN turned it back to off, they'd have gone off**
Racer, that's true also, but never got that far. I didn't expect the lights to stay on as they did. It was just an observation as I'd not experienced that before on my old '92 CVLXHPP when I had it. The '02 CVLXSport I traded for the MM didn't have the auto on lamp feature.
WIPERS ON....LIGHTS TOO
Remember that if your wipers are on or on delay your headlights will stay on. When you have them on the slowest delay you tend to forget and wonder why you've lost control of your lights.
Re: WIPERS ON....LIGHTS TOO
I knew that! Didn't know the other combination concerning the lights when they are active from the auto on finction, then turing them to off! Learning more each day!
Bob,
Something you might want to watch out for. I know its a pain, but might want to shut the car off when fueling, otherwise you may get the "check engine light" coming on. Apparently this happens when fueling the car running. It happens with other Fords and Lincolns. The only way to shut it off is take it to the dealer.
KSMM03 said:
Bob,
Chris. you can clear the light by disconnecting the battery for about 15-30 minutes, or if you know womeone with a code reader, you can clear it that way. Seems to me, that this item should clear itself once the cap is reinstalled. My daughters GenMotors car will clear itself.
you may also want to shut the car off while fueling because your car may EXPLODE! [at least that's what my wife tells me]
slowpoke
Whenever refueling your car==once out -stay out--do not re-enter car---reason-- Most static electricity( spark produced from us rubbing against seating against our clothing) occurs while exiting the vehicle--thus--Static electricity can spark from re-exiting the car while fuel vapors (Not fumes) are in the air--if spark hits vapors they( vapors) will iginite back to it's source--the gasoine--thus B O O M!!!===flash back---everthing g o n e ! Poof!! SO get out to re-fuel--stay out with the re-fueling process until completed and nozzle returned to it's halter--
Please! This has been an unpaid ad for your safety----MM man
