Headlight off delay time
TheFlatlander
Winter is overated
Just curious, My headlight off delay is a little bit short (I think). It seems to time out in about 18 seconds from vehicle shut off or innitiation from unlocking the door with the key fob.
That amount of time isn't long enough to get into the car or away from it most of the time. kinda almost annoying. Is this normal? What are the times on other MM's
This is the first auto headlight feature that I've had with Ford that doesn't have a time adjustment by the switch. Is this adjustable? Didn't see anything in the owners manual and the Service advisor is drawing a blank.....Thanks
I may be mistaken, but I thought the auto headlight delay was controlled by the dash light dimmer switch...ie...brighter the dashlights, the longer the delay. I dunno know where I read or heard that at, but it comes to mind.
Let me know if it is true.
Douglas
T-birds have what u are talkin about
My buddies 94 bid had auto off lights like the MM, and it had a dimmer style switch above or below the interior light switch.....it is similar, that may be what u are thinkin of?
Oh well just a thought....
-Dennis Stiles
My 2003 300a doesn't have any setting with the light switch to control the delay. I don't think that the dash dimmer switch is involved in this, that's just a dimmer switch. As far as I know, the auto headlamp function on the Marauder is fixed in terms of delay. Kind of a bummer. My '97 T-Bird had a seperate dial to allow you to adjust this.
The dimmer has no relation to the time delay. I'm pretty sure about that. (While we're on the dimmer there isn't much of a detent in the motion between full dash lights and interior light on...kind of poor design?)
Going back to the origional post though, how long is the delay time on other Marauders? With mine being just short of 18 seconds and is that the norm?
Also was looking since there is no dash mounted adjustment for the delay time if there was some "secret handshake" type of adjustment? Like how the annoying seat belt minder is turned off. Not everything is put in the manual-like for example that our vehicles actually have speed sensitive volume control or how to adjust it (addressed in an older thread)
I ran across this, look in the your car manual. I read something in the manual on how to make it a shorter or longer delay cycle. It just seem like a pain in the butt :flamer: to me on how to do it, but it can be done.
:mad2:
Flatlander,
My '04 DTR is the same as yours -> 18 sec. then shutoff as checked a few minutes ago.
The dimmer below is in fact for the dash lights / cabin lights as stated in some of the replys. My '01 GM did have adjustable delay however.
It's actually a different switch from the GM due to the MM having fog Lamps. Where is the time dely controled from, is it in the switch? and can it be modified?
Ok class lets try this.
1. Turn the headlamp switch to OFF.
2. Turn the ignition to RUN and then back to OFF.
3 Turn the headlamps switch to Autolamp position.
4 Wait the desired amount of time for delay, then turn the headlamp switch to off.
5 steps 1 to 3 need to be performed within 10 seconds.
Hope this works. :beer:
does anyone’s overhead console buttons light up? At night I can't find the build-in homelink garage door button! :mad2: On the 2003 Lincoln Continental the buttons light up in the overhead console so you can see what heck you’re doing.
Tomd, Thanks for the info. I will try out tonite when I get back to the MM and report back results.
Nope neither does mine or any one elses. there was a thread in the recient past of somebody adding LED's
No backlighting. Contact torinodan, he modded mine with LEDs. Looks nice. Better hurry though, he's supposed to deploy back to Afghanistan sometime this month.
Hey Teach, gave it a try and there was no change to the delay time, still 18 sec. I think something is missing.
Anybody been able to get this to work? Tried twice on my 2003 300a tonight with no joy. The headlamps are set at about 17sec, and I couldn't get that changed.
OOPS! You forgot tot tell 'em about running around the car, counter-clockwise, two times, then yelling "YAHOO", in front of each headlight as you pass, on sucessive trips. then...:rofl:
There's crazy sounding settings for just about every function you can think of: auto door locks, chimes, you name it.
Now about the radio speed/volume setting.
  • Push in and hold the volume knob for about three seconds, or so.
  • The display will give a message about speed setting.
  • While holding in the knob, push the UP arrow to setting 7
  • And there y'go, it's set.
Thanks to BigdogJim at the CAM BigBats DOO last Sunday. :D
Turns out it works on my '04MM, Barbara's '03 Aviator, AND my '02 F-150.;)
And yes Charlie, I KNOW it's 2AM. Us geezers have urges during the night. (note to self ...don't slam no do's at bedtime no more) (meanwhile, I voted for Mark);)
