How not to repair a compass....
fastblackmerc
Everything Marauder, LEDs & HI
How not to repair the compass in the overhead console.
Incorrect
Correct
Had to replace all the resistors as they were damaged by too much heat.
Funny, I was the one who soldered them
I tested each resistor after a few were cracked joints, it still didn't work
There may be another issue with it
Cold solder joints....
So which is it? Jim said it got too hot and burned up the resistors, and you say too cold?
The compass was flaking out and there was another spot on the board that looks like it got over heated
Since the guy who owns the compass was over at my house getting bad switches and other minor stuff taken care of, I pulled the compass out and found some issues with it :)
I did it as a favor, and left the compass out so he could send it to Jim for repairs
Maybe I just suck at soldering:lol:
Hope Jim finds the other issue with it
Cold solder joint means the wire/component wasn't heated up so the solder didn't flow to it and just sits there and blobs.
like so:
main-qimg-ed6c6ad361d1b2a7602a5b43ddfc5ec9
They look cold to me, but hey, it's not my thread....
I can say, you used too much solder, you used to big of a tip on your iron and needed a bit more heat. Perfect practice makes perfect. I'm doubtful that you burned up the resistors......very doubtful.
I'm hit or miss on soldering circuits.. Either it's the best you've ever seen or it's the biggest WTF out of your mouth. LOL
Now soldering pipe? I can run a mile of 4" or a bank of 2" water heaters, pumps, and controls, or even a design build mechanical room like a museum piece and never a leak! [emoji4]
The resistors are surface mount type. The solder pads are on the bottom of the resistor..... not the top.
I removed the excess solder from the top of the resistors, tried the compass, it didn't work. Removed the resistors, re-soldered them and it still didn't work. I then replaced the resistors, after tinning the solder pads on both the circuit board and the resistors. By tinning both surfaces to be soldered there is less chance of creating a cold solder joint.
I use an iron with a very small pencil tip and the highest lead content rosin core solder I can buy.
If I get a chance I'll try and post step-by-step pictures.
The resistors had the solder pads come off the body of the resistor. Too much heat.
Love a guy who can lay the pipe:o
