how to take programer off
Engine misfire
A/c refrigerant
Catalytic converters Eff
EGR Flow
Evaporative control system
Heated Catalyst
Heated Oxygen sensor
Secondary Air System
Oxygen Sensor
"ALL SAY NOT SUPPORTED"
THE ONLY 2 THINGS IN READY ARE
Fuel System proformance
Comprehensive Component
"Not Supported" means they are turned off in the tune, although not all of those items are supported in a Marauder in the first place. You need to have a new tune with the required monitors turned on.
Impala SS from the 94-95-96 era has tons more torque than stock marauder, marauder is not known for off theline performance in stock form. Some 4.10 gears will help in that case, which will require a tune. There is only so much a tune will do without other supporting mods
I'm not so sure all that is a result of monitors turned off. Engine misfire, A/C refrigerant? Al the O2 readings? WTF?
Someone with more smarts than me needs to chime in on possibility of communication problem to the emissions tester, or possible problem with the car.
Since you don't have a tuner to change anything, you might want to examine your car for existence of O2 sensors, EGR set up, write a list of mods done - then get a tuner with some good tunes from MartyO.
Contact him directly offline.
As I stated, not all of the monitors he listed are supported by the Marauder's OBD-II strategy.
My paperwork from the inspection station does list everything he posted, but the state's computer is smart enough to recognize which monitors are not applicable and doesn't ding you. It is also smart enough to realise that having everything "Not Supported" is not acceptable, either.
If his O2 sensors were missing (for instance), that monitor would show "Not Ready" instead of "Not Supported".
Why is this difficult?
Buy a tuner with a stock tune in one slot and a performance tune in another.
Load stock, take test, pass.
Re-load tune that was in there or performance tune from vendor.
Not rocket science.
And you texted me at 12:08 AM.
Do not do that again
