someone pay you to ask that question?????????
I drilled and tapped the aluminum throttle body adapter, then installed a Lightning-style threaded one just before the throttle body.
I'm not sure the location is that critical, as long as it's after the intercooler. The sensor element is pretty well isolated from the body of the sensor. The threaded and the o-ring mounted type sensors are pretty much the same in this regard.
We did have the IAT sensor tapped in the Procharger cast Intake but it was reading 10 degrees higher than the actual Intake temp so we moved it in between the Intake and the Intercooler.
JD,
Wouldn't you want it to see "All" of the heat the engine sees....radiant or not??![]()
The EEC pulls timing as heat rises and if IAT air in front of the engine is 130* and at the TB is 140* wouldn't you want the EEC to respond to the "Pre-TB" reading??![]()
Dave Lamberson may have a good answer for us on this one......
Happy New Year!!:beer:
Marauderjack:bandit:
