Idler replacement
marauder mama
I've got to replace the idler on my MM.
The small one, slightly to the pass. side.
Does anyone know how tight these things are suppose to be?
I've been told as tight as possible and I've been told just "snug it up".:confused:
If your replacing the idler I'd recommend replacing the tensioner also. They both get the same amount of wear.
Idler = 2.5Nm or 18 foot lbs
Tensioner = tighten in 2 stages - 1st tighten to 10Nm or 18 inch lbs, 2nd tighten additional 90 degrees.
Thanks guys,
I will replace the tensioner while I'm at it.
And I won't crank down on the bolt, "as tight as possible" didn't sound right
to me.
