Wanted To Buy megs tips
Just so you know, the 4" can only be hooked up to a 3" aftermarket exhaust setup. Also, if you want them, your best bet is to put in an order with coneng. They should be doing a run late this year.
Not true bud! the tips work fine on stock pipes:cool:
What????? :eek:
Where did you get that from??? :confused:
+1
I'm running the stock pipes from the mufflers on back with 4" tips. The only changes I made were the addition of flanges to allow quick changeover from the res-delete 4" to the OEM tips, should I ever wish to do so.
+1
Hey, that idea sounds familiar. :hmmm:
what a great idea..flanges to make changing the tips out if desired...i would have never thought of that
and i did talk with the fellow at cone eng...maybe later this year for more 4" tips
yep
