Metco-Drive Shaft Loop...
mercuryguy
i was looking in the market at a Metco Drive Shaft Loop part ### ( MDL2300 ) for MM & Crown Vic,s , 03-04 , I was wondering if any one has used this product and part Number , and i was wondering if it is a direct bolt on application ?!?!? and the quility and strength of the product ?!?! if it is a direct bolt on drive shaft loop ,does it get in the way of a stock routed exhaust system,or is there any other fabacation need>!?!?! or is it a good Direct Bolt on item?!?! or is there a better company with a better drive shaft loop product ?!?!?! the Metco is listed at 99.99 $$$.
I don't believe there is any other drive shaft hoop available.
I've had a Metco installed for years. It is a direct bolt in, fine with the stock exhaust and no other fabrication needed.
I have one, fortunately I can't tell you how well it works as I have not lost a drive-shaft. But it was a direct bolt-on and works with looks headers too.
Metco drive shaft loop
For 2003 Mercury Marauder direct bolt-on loop. Seven years ago
I bought my loop for $45.
Gotta Love It!
I have one and its direct bolt on. Just had to hammer down the valley on both sides a little to get better clearance for my drive shaft.
