Oh...the battery has been long dead. Sucks too...I need to figure out the beltminder disable code again. For my '04, it's not the same as documented, it's the one for the Grand Marquis (along w/ the documented front-end alignment specs also being incorrect).
So pulling the fuse on the fuel pump is the way to go (and not clicking the disable switch in the trunk)? Been awhile since I dug through the manual...I'm guessing it's clearly labeled?
I'm prepping...we're now getting flurries down here in Cent. IL (although Chicago got dumped on last night...so..we're not as bad) but I'm not going to take it out in anything worse than rain. Need to pick up a new battery.
Something else I'm concerned about is it looks like I had a shock leaking (or possibly brake fluid). There was some clearish looking something (although didn't seem overly greasy) puddling a little bit on the floor underneath the car inside of the left rear wheel. Hoping all the air suspension will work alright, etc. I've got an extended warranty and just over 16K so I'm expecting to be taking a visit to the dealer shortly after she gets fired up too.....
