60sec_assassin
SLOWER than few...FASTER than most!
I saw the other thread on a MM stalling but my stall problem started last summer. It started with the battery, noticed my volt meter running at a little over 12v with the car runinng so I replaced the battery, everything was fine for a few months then it would shut off if i was at low idle or at low idle in a turn at a light...(I've become an expert at re-starting in "N" and slamming back to drive". Did an alternator check and found it was bad so i replaced it today with a stock 130amp, later this evening i took it for a drive and everything is fine until i noticed while in park if i turn the wheel to either side my volt meter surges from 14 to 12v??? What could be the problem. After installing the new alternator i disconnected the battery while running and it stayed at about 14v....could there be another problem
