Well, not really, but it seems to be going through some growing pains. I've only been driving the car about six months since purchasing...the first month went great. I then had some Stainless works headers, borla mufflers, magnaflow x-tube and hi-flow cats installed and took the car to Fastlane motorsports for a new dyno tune. Since that time:
The car has thrown P0420 and P0430 (catalytic left and right) - I'm assuming the tune needs to turn these off for high flow cats.
The car has thrown P0301 (miscellaneous misfire) twice...Seems to be stumbling periodically too. I guess I'll start with a MAF, TB, IAC and TPS clean, maybe new plugs.
The shifting is all screwed up now. I get RPM fluctuations around 2000 RPM when letting off the gas. The RPMs surge up/down before dropping to idle. I also get shifting into/out of overdrive rapidly at semi-WOT whether with O/D turned on/off.
The car inconsistently goes into Reverse. From P to R it does fine. From D to R, the car 25% of the time doesn't actually go into R.
The A/C quit working...Blows hot air only. Actually hasn't worked at all since I bought it, but I had to store it through the winter and this summer is the first time I've actually tried it.
The car has developed a squeak in the suspension....I'll start doing some research, but is there a common cause in MMs for this? Car only has 30K miles on it.
I had a Lidio tune on the car prior to the SW headers with no issues. I know some of the issues like the squeaking, A/C and reverse are not tune related, but I'm thinking of going back to a Lidio tune (tailored for headers) and dumping the custom tune. Or maybe give them another shot at fixing it, as I'm certain the strange shift points and the errant codes are partly from the new tune.
Not venting or wanting sympathy, but any suggestions on where to look on some of these issues would be greatly appreciated. Like, oh yeah, that's a common problem, do this
This car is my daily driver and I'm currently working 12 hours a day, so my time to work on it is limited but I still need her for transportation.
