Ms. Denmark
Girls Just Wanna Have Fun!
Hey gang.
I think, or actually Mr. Man thinks I may have an IAC issue(whatever that is) with my '04 SB. The car needed a jump as it sat a bit to long since the last time I had it running. Car started right up and settled into it's usual idle. While Mr Man was coiling the jumper cables back up the car suddenly jumped up in idle speed to around 12-1300 rpm. I pushed on the gas pedal and it revved up, but took its sweet time coming back to the 12-1300 rpm speed. We let the car warm up a bit thinking it may be the computer doing its thing though I don't recall it ever doing that before.
We took it for a short drive thinking perhaps something just needed to work itself out, but alas that didn't work either.
Mr. Man popped the hood and removed the plastic thingy that covers the throttle cable and said the cable is sitting against its stop and it revved freely by hand but would not return to proper idle.
He then pulled the cable thingy off the chrome fuel filter looking thingy and the car surged slightly then dropped idle and took a gasp and revved itself back up to a high idle. He put the connector back on and we are back to the high idle. He says the IAC and or the throttle body maybe dirty or going bad. Is that chrome thing the IAC? How hard is this repair/service to do? I worry about his back leaning over the car. He is stubborn and will try to fix it himself if its not a complicated job. Need advice if it sounds like we are on the right track as far as the problem is concerned and if we should try to fix the problem ourselves or take it to Ford.
Thanks for any information.
Ms.D
Ms.D
