Never Fail Headlights
fastblackmerc
Everything Marauder, LEDs & HI
Looking to see if there is any interest in a headlight kit - one of my repaired LCMs and an upgraded harness for the headlights.
Since you'll be running upgraded relays in the LCM and using relays in the harness the headlights should never fail (unless a blub burns out) and your headlights should be brighter.
Projected cost - $175.00.
This sounds like it could be the cure all for dim head lights. With the upgrade what have found the voltage reading at the head light bulb socket ?
I would be interested, yes. Eventually my car will need an LCM, and doing the harness at the same time would make sense.
