Post your pics when you done!!!!!Got my kit today. Can't wait to install tomorrow!
Someone should try putting 3000k kit into the fog lights. Would make a pretty cool contrast with 600k or 8000k in the headlights.
Same bulb 9007 but the Hi/Lo kit comes with an actuator inside the light bulb that will slide the bulb in or out (can't remember) to shift the beam of light inside the halogen lens which.
It's a single bulb that shifts the light beam.
This is 9007 Hi/Low HID bulbs
http://www.youtube.com/watch?v=HeJ25pRJCv8
Watch at the 0:47 mark it's real quick where you can see high beam flick
http://www.youtube.com/watch?v=UtsguU-mHCU
Why don't you do it????
IMHO.... that will look like crap.
Actually the right way would be to retro fit a projector with an HID bulb. Real HID projectors do not change the power/light output, when high beam is activated a shield inside the projector moves down and allows more light to pass through, that's why real hid vehicles have a very defined light cut off. This is only the cause with Bi-Xenon projectors in which the vehicle does not have a halogen high beam setup.:shake: :shake: :shake: :shake:
That's what I thought.
You need to do it the RIGHT way and get a HID kit that has two 9007 bulbs in the same socket, one for Hi, one for Lo and 4 ballasts.
Cool man!!!!!! hope to see them pics soon
I just put my kit in today. Does anyone else have an issue with only one headlight turning on sometimes?
Not true you still have to modify the housing, yes a tab is removed but the bulb is still to wide to fit. At least the standard halogen bulb is, not sure about a HID bulb.Sorry for the lack of update but the damn fog lights are a pain in the ass. Seems you have to cut up the stock connector and glue it together to the h1. Then you have to pull the fog light housing out and maybe modify it to carefully insert the hid bulb if you don't want to break it. I still haven't found time to finish them.
I should of listened to the one guy who said a 9006 fits with only cutting a tab off, stupid me..:mad2:
Only negative thing I have is that the positive and negative for high/low beam are reversed with this kit but I figured that out and was simple to correct. Other than that no complaints from me about it.Soooo....are there no negative comments for these lights....if so I can smell a new item being added to my christmas list![]()
Since i dont feel like reading 10 pages, has anyone else had this issue with reversed wires?
I'm probably going to be ordering this kit for the truck, if it breaks im blaming you
It sounds like they are better than the $60 HID kits my friend got for his crown vic off ebay, sometimes they wouldnt want to turn on lol
