L8 APEX said:Hey Dan! another late night at the shop also know as Performance Research to a few. Got all the stock stuff down and starter loose and starting to go back in tonight. I have developed a few tricks of my own for these header installs. You have to when you do them regularly. We learned a lot on Logan's G-ride that is because he is the first local guy with everything. The bottom of the car is very clean with exception to ATF drops which I assume was do to a recent service since it looks dry elsewhere. The car has a lot of bottom end rattle on cold startup is this a normal Marauder trait? You may want to play with oils or filters to see if it redueces startup knock. Anyway, I am going to bed then another long hard day tomorrow. The Lighting transmission I was diagnosing ahead of you ended up needing a rebuild so I am balancing both this week along with a header install on another Lightning Friday:help: . Later, Terry.
How cool is this?!? This shop knows it's easier to find me here than at my contact numbers...you just gotta love that.
Good Morning Terry- The ATF is from last Thursday's fluid change. The cold- start rattle has always been there (bought with 13 miles)- Normal? I'm not sure... I might come by after to work to check on her- I don't want to rush y'all- I just liking hanging out there...Performance Research- I like the sound of that. :up:
-Dan
