Floridadave
Hi everyone, I purchased my 04 Marauder a few weeks ago and have been enjoying her. She has 128k on the odometer but is in good condition otherwise. (Previous one owner Texas car with clean car fax and extensive maintenance receipts ) I've noticed a stumble on accel, so I took it this past weekend to a shop I do some piece work for. They let me use their expensive scanner to run diag on it. Sure enough, misfires on cylinders 1 and 2 so I purchased all new coils and plugs thru our local ford dealership. Was able to get them basically at cost as my wife works at a local honda dealership.
Tomorrow I'm dropping the car off at a local exhaust shop to remove the rear cats and install 40 series flowmasters, I guess I'll install cops and plugs Wednesday morning when it's cold. I read thru multiple posts on here for replacing the COPS, and I was a master tech at Honda so I'm hoping it's as easy as it should be, (no broken connectors/ seized plugs) fingers crossed.
I do have a question though regarding the a/c, I see there are probs with the EATC causing the air not to blow through the vents due to vacuum leaks. My car seems to not blow thru the vents as hard as it should be when set to max. Is that an oring issue or something else? I did own an 05 MGM before I acquired the Mm and the ac had way more flow thru the vents,
Thanks in advance
Thanks in advance
