PCV Coolant Hose?
bolsen
dont know jack, but trying
I pulled the PCV coolant hose and fluid came SHOOTING out everwhere.
My question(s) is this; Why? Is it bad? Is it just water? Do I need to replace fluid somewhere? Do I just let it drain into an empty container? Is this normal?
Lotsa questions today LOL. If I didn't have this resource, who knows how much $$$ I wouldv'e wasted at a mechanic.
PCV vacuum hose?
The one that goes tot he PCV valve on the right side cam cover?
The hose on the right. I mean fluid came out with some pressure.
It's normal. The PCV system in the 4V motor is "heated" by the cooling system to prevent the moisture present in crankcase gasses from freezing in cold weather.
Yes, you'll need to replace the amount of coolant you lost.
Anti Freeze? It smelled like nothing and was clear so I assumed it was water from somewhere.
Also I panicked and put the hose back on right away. When I take it off again, should I just let it drain into a container? How much will come out?
Damn...All I wanted to do was take off the manifold and clean the oil out of it. Now I just created an all day project with burping involved. Any other tips for removing the Upper IM? I want to clean out the oil before I install my catch.
