Coming after the first of the year:
NEW: Wilwood factory front kits for the Crown Vic spindle.
Wilwood will finally have their own factory front Big Brake Kits available for the Panther platform. Due to the expanded use of the front clip in many restorations and the success that TCE has had in this market for the past few years Wilwood has expanded their own line of kits to cover this platform. This mean you'll have access to kits featuring full Wilwood product; Calipers, Pads, Hats and Rotors. And while TCE has been using some of that for a variety of time, you'll have your option of vendors to purchase from and follow up with your serivce needs. *We'd like to think you'd still consider TCE....after all we worked closely with them in the specs and data to produce this kit.
These new kits will be available in three flavors:
12.88 x 1.25 FNSL6
14.0 x 1.25 FNSL6
14.0 x 1.25 AERO6
Final pricing is not yet available. And due to MAP (minimum advertised price) restrictions we may have to jocky some numbers to publish them so please be patient.
The good news is that it will mean a reduction in final cost a bit beyond our own "house" kits. That will also mean a lower cost on options such as "Drilled and Slotted" vs our current charge.
For Marauder owner these first two kits will require a 1/8" wheel spacer and for the Aero kit a 1/2" wheel spacer. For those who wish to retain the factory MM wheel you'll need to stick with our original kits.
12.88 x 1.25 FNSL6
14.0 x 1.25 FNSL6
14.0 x 1.25 AERO6
