Question for all the gurus.
parker
Ok, I've been working on my car "eaton swap marauder" over the past few months i.e. ported blower, bigger h/e, iw crank pulley, modified FMPD and some other things. I got it all back together and now it won't stay running. It will crank and idle up to 1200rpms and then die. I can hold the throttle down and it will run. Could that be the ICV or just old gas? Just looking for some good direction. Haven't had a lot of time to work on it with all the rain down here in the south so just looking for some areas to look for when I get a chance to work on it again.
check the spliced wires to to TPS. May be check all splices,test to see that the wire is sending the juice.
