Questions For Lidio
Bob Mathis
Bob Mathis here Lido. I have a couple questions. I have a set of 03 Cobra heads complete. Are the cams good for use in my S/C marauder? Also can you please tell me something about this block, I all so have? The Casting #RF1L2E-6015-BB. The box has a PN 1L27-6010-BA.
Thanks Bob
Thanks Bob
Bob
The heads and cams from the 03-04 Cobra are the same as the 03-04 Marauder and Mach-1 plus the Aviator. As far as the block goes I cant help on those numbers... Maybe one of the other members will see them and look into it for you. Although, is this new block iron or aluminum?
Thanks
Tune for headers
Lido,
I have a Xcalibrator2 that i bought from you. I recently installed my Kooks headers. Is the the 4:10 tune already set for headers? If not, what adjustments should i make with my progamer? Should i adjust my air/fuel ratio?
Current mods installed:
4:10 gears W/STUD GIRDLE
JLT RAM INTAKE
KOOKS HEADERS/BASSANI X-PIPE/SUPER 40'S/DELETE TIPS
Thanks Bob
When I go into work tomorrow I'll ask the fellas in the parts dept about those numbers and see if I can come up with anything for you, worth a shot.
*edit* They couldn't find anything on the part or casting #s, odd, they look like valid Ford #s, they tried cross-referencing and checking for superceded #s but nothing came up... sorry.
MADDOG said:
Lido,
JLT RAM INTAKE
You really should get the A/F checked now that you've installed headers and probably a 2.5" exhaust of some sort. Believe it or not, the A/F on some cars doesn't go that lean or lean enough to worry about at WOT with a header and exhaust install. But its best to get it looked at.
hey with the 4:10 gears does the cut the hp down my friends who deals with mustang told me this is there any truth to that
No, nor does it increase the HP. .
