AConvertedChevy
Asphalt Assassin
my radio works fine till i hit the rear defroster button, then its all static
any idea why that is? anyone else have this problem?
The crown vic at my fire department has this issue and also has the wack wipers... not good during a snow storm!! Can't hear the radio and the windshield wipers only worked when they wanted to... very dangerous!
Haven't had any issues with my radio, but I just corrected the "wacky wiper syndrome" on the Bluesmobile. Check out Richy04's post on cleaning out the debris from the wiper motor cowling, that should do the trick.
http://www.mercurymarauder.net/forums/showthread.php?t=47864
I waited just a bit too long on mine and ended up frying the motor. Whole process shouldn't take much over an hour; hardest part is getting the wiper arms off.
I will relay the message to the town mechanic! Thanks!
Do you guys have metallic tint on the rear window? Sometimes that can cause this problem.
i agree, i hate those things! whats wrong with a friggin screw~!
I too have this problem. I think the only cure is an aftermarket radio.
