SIZEMOREMK
Junior Member
Had an overheating incident the other morning that we thought was the result of overheating due to frozen thermostat.
Turns out both HGs are blown and some pistons are burnt, but the shop says that it looks like I had been having a good bit of detonation and that the theadgaskets were probably leaking for some time; also said the bearings showed signs of detonation.
I have never had what I thought would have been an indication that my engine was detonating, never heard or felt anything... The car had no knock sensors, but I believe I will be having them put some knock sensors back in it.
My tune was suppose to have been pretty conservative, as this is my daily driver... Really need to find root cause of the detonation.
Anyways didn't mean to run with those details, but I have a question on replacing pistons:
The guy says that the bores look like they could be re-honed and just put new pistons, rings, and bearings in it.
It has been some time since I have rebuilt an engine, but a decade or more ago I was under the impression that one didn't simply just swap in new pistons.
The couple of machine shops I dealt with years ago needed the pistons in-hand to properly size the bores due to manufacturing tolerances and such.
Have the piston manufacturers tolerances improved over the years?
I am kinda concerned about piston to wall clearance.
Or am I just worrying too much, and is putting new pistons in used bores normal?
