[TABLE="width: 80%"]
[TR]
[TD="width: 15%"]
OBDII Monitor
Exercised[/TD]
[TD="width: 60%"]
Drive Cycle Procedure
[/TD]
[TD="width: 25%"]
Purpose of
Drive Cycle Procedure[/TD]
[/TR]
[TR]
[TD="width: 15%"]
Drive Cycle
Preparation[/TD]
[TD="width: 60%"]
1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset.[/TD]
[TD="width: 25%"]
Bypasses engine soak timer. Resets OBDII Monitor status.[/TD]
[/TR]
[TR]
[TD="width: 15%, align: center"][/TD]
[TD="width: 60%"]
2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE.
Start vehicle WITHOUT returning to Key Off.[/TD]
[TD="width: 25%"][/TD]
[/TR]
[TR]
[TD="width: 60%"]
3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7°C (170° F).[/TD]
[/TR]
[TR]
Prep for Monitor Entry[/TD]
[TD="width: 60%"]
4. Is IAT within 4.4 to 37.8°C (40 to 100° F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000.[/TD]
[TD="width: 25%"]
Engine warm-up and provide IAT input to the PCM.[/TD]
[/TR]
[TR]
HEGO[/TD]
[TD="width: 60%"]
5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes.[/TD]
[TD="width: 25%"]
Executes the HEGO monitor.[/TD]
[/TR]
[TR]
EVAP[/TD]
[TD="width: 60%"]
6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85%[/TD]
[TD="width: 25%"]
Executes the EVAP Monitor (If IAT is within 4.4 to 37.8° (40 to 100°F))[/TD]
[/TR]
[TR]
Catalyst[/TD]
[TD="width: 60%"]
7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period.[/TD]
[TD="width: 25%"]
Executes the Catalyst Monitor.[/TD]
[/TR]
[TR]
EGR[/TD]
[TD="width: 60%"]
8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times.[/TD]
[TD="width: 25%"]
Executes the EGR Monitor.[/TD]
[/TR]
[TR]
SEC AIR/CCM (Engine)[/TD]
[TD="width: 60%"]
9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes.[/TD]
[TD="width: 25%"]
Executes the ISC portion of the CCM.[/TD]
[/TR]
[TR]
CCM (Trans)[/TD]
[TD="width: 60%"]
10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times.[/TD]
[TD="width: 25%"]
Executes the transmission portion of the CCM.[/TD]
[/TR]
[TR]
[TD="width: 15%"]
Misfire & Fuel Monitors[/TD]
[TD="width: 60%"]
11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times.[/TD]
[TD="width: 25%"]
Allows learning for the misfire monitor.[/TD]
[/TR]
[TR]
[TD="width: 15%"]
Readiness Check[/TD]
[TD="width: 60%"]
12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13.[/TD]
[TD="width: 25%"]
Determines if any monitor has not completed.[/TD]
[/TR]
[TR]
[TD="width: 15%"]
Pending Code Check and Evap Monitor "Bypass" Check[/TD]
[TD="width: 60%"]
13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.
Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8° C (40 to 100° F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.
Proceed to step 14.[/TD]
[TD="width: 25%"]
Determines if a pending code is preventing the clearing of P1000.[/TD]
[/TR]
[TR]
Evap Monitor "Bypass"[/TD]
[TD="width: 60%"]
14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1.[/TD]
[TD="width: 25%"]
Allow the "bypass" counter to [/TD]
[/TR]
[/TABLE]
