Svashtar
Trying to get it right...
I got the kit from Jay but haven't installed it yet. I was concerned about running too rich, but think I will install it and then try and get the car dynotuned to see how it's doing.
I had a question for whoever, and it makes more sense to install it in this thread than over at the Garage I think.
I opted for the optional $10 S&B breather filter from Jay, that screws onto the valve cover PCV. Jay says this keeps oil out of the intake, which obviously makes sense now that there is no direct connection. Plus it is a very nice looking little breather filter. He had initially sent me a standard RAI with the 90% elbow for the PCV valve cover hose, but quickly sent me a replacement RAI tube with no fitting when I pointed it out to him.
I mentioned this setup to another forumite, and he informed me that I would be better off with the standard PCV hose setup, as that creates vacuum in the crankcase, which in turn adds horsepower to the car. (?) He said that breather filters used to be used in Nascar apps, until they determined that the standard PCV hose into the intake setup created significant crankcase vacuum which in turn helped performance. (Of course those are what, 600 HP cars?)
He said he uses a Steeda $59 oil seperator instead to make sure no oil gets to the intake, and to monitor the amount of oil running through the PCV hose.
So, I'm polling the experts here. Would I have been better off from a HP standpoint to use the standard valve cover to RAI hose, or will the valve cover breather filter work about the same?
Thanks for any input!
Regards,
Norm
Regards,
Norm
