Marauderjack
Senior Member
Hey folks,
I have had a ScanGauge II for over a year now and it is very nice and does a bunch of things so I decided to get a new one with the "Xgauge" feature to read fuel pressure and other stuff......I plan to send the older one back for reprogram when they are ready to do the reprograms!!:beer:
Well.....today I had a little time and decided to add some Xgauge functions to it and after about 30 minutes of figuring it out I was able to add "Horse Power", "Cylinder Head Temp" and "Trans Fluid Temp" for starters!!
WOW.....it works ABSOLUTELY FANTASTIC!!!:bows:
Cruising at 60 MPH with ambient temp of 84* it reported CHT of 204* and TFT of 198* while water temp was 200*......sounds reasonable??
The HPR was at about 37 HP on the level at 60 MPH while at idle with all accessories on it reported 12-13 HP......interesting!!
Now to see some higher "HP" numbers so I launched it from a stand still at about 1/2 throttle and got 383 HP with about 3.5 PSI......later ran up to about 7.5 PSI and briefly saw 470 HP.....so it sounds about right at the flywheel??:beer: How does it know this stuff???
I had no idea this thing was so advanced and seemingly accurate....I also didn't know all of this info was even available at the OBD II port!!!:shake:
Next I plan to program torque input to the torque converter to see how that relates to HP??
I only wish it would lock in peak readings...and it may be able to but I ain't figgered it out yet!!
Thanks to Ron and Joey for a GREAT tool!!!!:bows:
Marauderjack:burnout:
