This is the one you want. It has the "screw" bottom and NOT the "helix".
SCREW - Marauder
http://www.ebay.com/itm/Metco-MBR00...Parts_Accessories&hash=item1c25647e5f&vxp=mtr
HELIX - Crown Vic
The "screw" works for the Mustang and Maruader, and the "helix" works for the CV.
Putting that together with a comment about the PVC instruction being wrong on the trilogy instructions on another thread that may be my problem. Where do I connect the breather? In liu of the PVC or somewhere else?
WWW. JLT. com The metco breather less than 50 bucks and delivered within 24-36 hours to your door :banana2: [ Yes they sell the Famous JLT cold air intake for the MM ]I found the page, but none are compatible. I thought the one at the bottom was it, but it says it is not.
http://www.ebay.com/sch/i.html?_nkw...rcury+marauder+metco+valve+breather&_osacat=0
The Muscle Mercs catch can will work on your car :beer:http://mustangboards.com/modular-4-6l-tech/41020-pcv-system-questions.html
OK looks like PVC/crankcase air is definitely metered. So some variation of closed filtration is the way to go.
Seems oil airation may be causing the problem. Mine was so day and night because of the larger pressure changes/faster revs/higher power.
Still not ruling out the breather, I will bounce it off of JDM as they are in on this. Ordered the steeda. I'm not always under the hood so the clear bottom will remind me to dump the waste. Hasn't smoked on start in a couple of weeks, but I'm sure it will be back if this isn't the problem. I'll post to this thread post install if the smoking persists.
